Reset system functions to reset all statistics counters on the console port. Depending on your hardware platform, the console port displays as console or 10101.
Switch:1> enable
Reset the statistics counters:
Switch:1# sys action reset counters
Are you sure you want to reset system counters (y/n)? y
The following table defines parameters for the sys action command.
| Variable | Value |
| reset {console|counters} | Reinitializes the hardware universal asynchronous receiver transmitter (UART) drivers. Use this command only if the console connection does not respond. Resets all the statistics counters in the switch to zero. Resets the console port. |
