Enabling CLI access levels
Enable CLI access levels to control the configuration actions of various users.
Important
Only the RWA user can disable an access level on the switch. You cannot disable the RWA access level on the switch.
The system preserves these configurations across restarts.
Block CLI access to Layer 1:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#no password access-level l1
The following table defines parameters for the password access-level command.
| Variable | Value |
| WORD<2–8> | Permits or blocks this access level. The available access level values are as follows:
 To set this option to the default value, use the default operator with the command. By default, the system permits all access levels. To block an access level, use the no operator with the command. |
