BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see VOSS Feature Support Matrix.
Use the following procedure to display BFD statistics for IPv4 or IPv6 interfaces.
The following example displays BFD statistics for IPv4 interfaces.
Switch:1>show ip bfd stats
                              BFD staticstics - GlobalRouter
MY_DISC    YOUR_DISC  NEXT_HOP     PACKT_IN     PACKET_OUT   LAST_UP                    LAST_DOWN
1          0          192.0.2.10   4661750      4620630      Mon Sep  6 15:31:15 2021   Mon Sep  6 15:28:08 2021
            The following example displays BFD statistics for IPv6 interfaces.
Switch:1>show ipv6 bfd stats
1       0        2001:DB8:0:0:0:0:0:ffff  4661750      4620630      Mon Sep  6 15:31:15 2021   Mon Sep  6 15:28:08 2021
The following table defines parameters for the show ip bfd stats command.
| Variable | Value |
| vrf | Specifies a VRF instance by VRF name. |
| vrfids | Specifies a VRF or range of VRFs by ID. |
