Use the following procedure to display IPsec information on an interface.
Display the IPsec status on a VLAN interface:
Switch:1>show ipsec interface vlan 22
                          VLAN Interface Policy Table
Vlan Interface         Policy Name            IPsec State          Direction
22                    AAA                   Enable                both
22                    tcp                   Enable                both
22                    icmp                  Enable                both
The following table defines parameters for the show ipsec interface command.
| Variable | Value |
| gigabitethernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| mgmtethernet mgmt Note:
                                     Exception: only supported on VSP 8600 Series. | Identifies the interface as the management interface. |
| loopback <1–256> | Specifies the loopback interface. |
| vlan <1-4059> | Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. |
