This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the remote Intermediate-System-to-Intermediate-System (IS-IS) system statistics.
- Select Stats Remote.
- Select the System Stats tab.
System Stats Field Descriptions
Use the data in the following table to use the System Stats tab.
| Name | Description |
| CorrLSPs | Indicates the number of corrupted in-memory link-state packets (LSPs) detected. LSPs received from the wire with a bad checksum are silently dropped and not counted. |
| AuthFails | Indicates the number of authentication key failures recognized by this Intermediate System. |
| LSPDbaseOloads | Indicates the number of times the LSP database has become overloaded. |
| ManAddrDropFromAreas | Indicates the number of times a manual address has been dropped from the area. |
| AttmptToExMaxSeqNums | Indicates the number of times the IS has attempted to exceed the maximum sequence number. |
| SeqNumSkips | Indicates the number of times a sequence number skip has occurred. |
| OwnLSPPurges | Indicates the number of times a zero-aged copy of the system's own LSP is received from some other node. |
| IDFieldLenMismatches | Indicates the number of times a PDU is received with a different value for ID field length to that of the receiving system. |
| PartChanges | Indicates partition changes. |
| AbsoluteValue | Displays the counter value. |
| Cumulative | Displays the total value since you opened the Stats tab. |
| Average/sec | Displays the average value for each second. |
| Minimum/sec | Displays the minimum value for each second. |
| Maximum/sec | Displays the maximum value for each second. |
| LastVal/sec | Displays the last value for each second. |
