This procedure does not apply to VSP 8600 Series.
Use this task to view IPv4 Address Resolution Protocol (ARP) information.
- Expand Mgmt Instance.
- Select Mgmt.
- Select the IpArp tab.
IpArp Field Descriptions
Use the data in the following table to use the IpArp tab.
| Name | Description |
| Address | Shows the IPv4 address of the ARP entry. |
| Instance | Shows the Management Instance ID. |
| IntfName | Shows the Management Instance interface name for the ARP entry. |
| MacAddr | Shows the MAC address for the ARP entry. |
| State | Shows the state of the ARP entry. The state can be one of the following:
