Enable RADIUS authentication globally to allow all features and functions of RADIUS to operate with the RADIUS server.
- Select RADIUS.
- Select the RADIUS Global tab.
- Select Enable.
- In the MaxNumberServer field, type a value for the maximum number of servers.
- In the AccessPriorityAttrValue field, type an access policy value (by default, this value is 192).
- Configure the rest of the parameters in the RADIUS global tab.
- Select Apply.
RADIUS Global Field Descriptions
Use the data in the following table to use the RADIUS Global tab.
| Name | Description |
| Enable | Enables the RADIUS authentication feature globally. |
| MaxNumberServer | Specifies the maximum number of servers to be used, between 1 and 10, inclusive. |
| AccessPriorityAttrValue | Specific to RADIUS authentication. Specifies the vendor-specific attribute value of the access-priority attribute to match the type value set in the dictionary file on the RADIUS server. The valid values are 192 through 240. The default is 192. |
| AcctEnable | Enables RADIUS accounting. |
| AcctAttriValue | Specific to RADIUS accounting. Specifies the vendor-specific attribute value of the CLI-command attribute to match the type value set in the dictionary file on the RADIUS server. This value must be different from the access-priority attribute value configured for authentication. The valid values are 192 through 240. The default value is 193. |
| AcctIncludeCli | Specifies whether you want CLI commands included in RADIUS accounting requests. |
| ClearStat | Clears RADIUS statistics from the device. |
| McastAttributeValue | Specifies the value of the Mcast attribute. The valid values are 0 through 255. The default value is 90. |
| AuthInfoAttrValue | Specifies the value of the authentication information attribute. The valid values are 0 through 255. The default value is 91. |
| CommandAccessAttrValue | Specifies the value of the command access attribute. The valid values are 192 through 240. The default value is 194. |
| CliCommandAttrValue | Specifies the value of the CLI command attribute. The valid values are 192 through 240. The default value is 195. |
| AuthInvalidServerAddress | Displays the number of access responses from unknown or invalid RADIUS servers. |
| SourceIpFlag Note:
                                     Exception: only supported on VSP 8600 Series. | Includes a configured IP address as the source address in RADIUS packets. The default is false. RADIUS supports IPv4 and IPv6 addresses with no difference in functionality or configuration. |
| CliCmdCount | Gives the value for the CLI command count. Specify an integer from 1 to 40. The default is 40. |
| CliProfEnable | Enables RADIUS CLI profiling. |
| SupportedVendorIds | Shows the vendor IDs that the software supports for RADIUS. |
| RadiusReachability | Specifies the mode for RADIUS reachability. Status-server mode provides a standard-compliant method for RADIUS reachability. Use-radius mode requires the configuration of dummy packets that are sent to RADIUS servers. The default is use-radius mode. |
| SecureEnable | Enable RADIUS Security (RADSec). |
| UserName | Specifies the username for RADIUS server reachability. The default is extremenetworks. |
| Password | Specifies the password for RADIUS server reachability. The default is extremenetworks. |
| Confirm Password | Confirms the password for RADIUS server reachability. |
| Unreachable Timer | Specifies, in seconds, the interval between checks when radius server is unreachable. The default is 60 seconds. |
| Keep Alive Timer | Specifies, in seconds, the interval between checks when radius server is reachable. The default is 180 seconds. |
