Use the following procedure to enable RMON on an interface.
- Enable RMON on a VLAN:
- In the navigation pane,
expand the  folders.
- Click VLANs.
- Click the Advanced tab.
- In the row for the
VLAN, double-click the RmonEnable field, and then select enable.
- Click Apply.
- Enable RMON on a port:
- In the Device Physical
View, select a port.
expand the  folders.
- Click General.
- Click the Interface tab.
- For the RmonEnable field, select enable.
- Click Apply.
