View multiple spanning tree instance (MSTI) port statistics to manage network performance.
- Click MSTP.
- Click the MSTI Port tab.
- Select a port, and then click Graph.
MSTI Field Descriptions
The following table describes parameters on the MSTI tab.
| Name | Description |
| ForwardTransitions | Specifies the number of times this port has transitioned to the forwarding state for this specific instance. |
| ReceivedBPDUs | Specifies the number of BPDUs received by this port for this spanning tree instance. |
| TransmittedBPDUs | Specifies the number of BPDUs transmitted on this port for this spanning tree instance. |
| InvalidBPDUsRcvd | Specifies the number of invalid BPDUs received on this port for this spanning tree instance. |
