Associate a port to a Virtual Router Forwarding (VRF) instance so that the port becomes a member of the VRF instance.
You can assign a VRF instance to a port after you configure the VRF. The system assigns ports to the GlobalRouter, VRF 0, by default.
- In the Device Physical View tab, select a port.
- Click General.
- Click the VRF tab.
- To the right of the BrouterVrfId box, click the ellipsis (...) button.
- In the BrouterVrfId dialog box, select the required VRF.
- Click OK.
- Click Apply.
VRF field descriptions
Use the data in the following table to use the VRF tab.
| Name | Description |
| VrfIds | Shows the VRF ID. |
| VrfNames | Shows the VRF name. |
| VrfCount | Shows the number of VRFs to which the port is associated. |
| BrouterVrfId | Specifies the VRF ID for a brouter port. |
| BrouterVrfName | Shows the VRF name for a brouter port. |
