This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the remote SPBM interface parameters.
- Select SPBM Remote.
- Select the Interfaces SPBM tab.
- Select Insert to create a remote SPBM instance on the interface.
- Configure the remote SPBM interface parameters.
- Select Insert.
Interfaces SPBM Field Descriptions
Use the data in the following table to use the Interfaces SPBM tab.
| Name | Description |
| Index | Specifies an Index value for the remote SPBM interface. |
| SpbmId | Specifies the remote SPBM ID. |
| State | Specifies whether the remote SPBM interface is enabled or disabled. |
| Type | Configures the remote SPBM instance interface-type on the IS-IS interface on the specific port or MLT, the values are point-to-point (ptpt) or broadcast (bcast). The system supports the ptpt interface type only. |
| L1Metric | Configures the remote SPBM instance l1-metric on the IS-IS interface on the specific port or MLT. The default value is 10. |
| Origin | Specifies the source of the remote SPBM instance configuration.
