Display information about classless interdomain routing (CIDR) routes.
The following table defines parameters for the show ip bgp cidr-only command.
| Variable | Value |
| <prefix/len> | Specifies an exact match of the prefix. This variable is an IP address and an integer value from 0–32 in the format a.b.c.d/xx. |
| vrf WORD<1–16> | Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
| vrfids WORD<0–512> | Specifies a range of VRFs by ID number (the ID ranges from 0–512). |
