Viewing the local SA cache
View the local SA cache to display the (S, G) state the router learns from local Protocol Independent Multicast - Sparse Mode (PIM-SM) entries.
- Click MSDP.
- Click the SA-Cache-Records tab.
SA-Cache-Records field descriptions
Use the data in the following table to use the SA-Cache-Records tab.
| Name | Description |
| TypeInformation | Shows the SA cache type. The SA cache type can be local or foreign cache. |
| GroupAddr | Shows the group IP address of the SA cache entry. |
| SourceAddr | Shows the source IP address of the SA cache entry. |
| OriginRP | Shows the RP address of the SA cache entry. |
| OriginatorAsNumber | Shows the AS number of the originator. |
| RouteType | Shows the type of route used for Reverse Path Forwarding checking. The value can be rip (1), ospf (2), static (3), bgp (4), isis(5) or none (6). |
