Check OSPF errors for administrative and troubleshooting purposes.
Variable definitions
The following table defines parameters for the show ip ospf port-error command.
| Variable | Value |
| {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| vrf WORD<1-16> | Specifies the VRF by name. |
| vrfids WORD<0-512> | Specifies a range of VRFs by ID number. |
