Edit the existing RSMLT configuration for the local node in the cluster.
- In the navigation pane, expand ConfigurationIPv6.
- Select RSMLT.
- Select the Local tab.
- Select a cell to change the value.
- Select Apply.
Local field descriptions
Use the data in the following table to use the Local tab.
| Name | Description |
| IfIndex | Shows the route SMLT operation index. |
| Ipv6Addr | Configures the IPv6 address of the RSMLT interface. |
| Ipv6PrefixLength | Configures the IPv6 prefix length. |
| Enable | Enables or disables RSMLT. The default is disabled. |
| HoldDownTimer | Defines how long the recovering/rebooting switch remains in a non-Layer 3 forwarding mode for the peer router MAC address. The default is 60. |
| HoldUpTimer | Defines how long the RSMLT switch maintains forwarding for its peer. The value is a range from 0 to 3600 seconds or 9999. 9999 means infinity. The default is 1800. |
| OperStatus | Displays the RSMLT operating status as either up or down. |
| SmltId | Specifies the ID range for the SMLT. |
| VlanId | Configures the VLAN ID. |
| MacAddr | Configures the MAC address of the VLAN. |
| VrfId | Indicates the virtual router ID to which the local RSMLT instance belongs. |
| VrfName | Indicates the virtual router name to which the local RSMLT instance belongs. |
