Use this procedure to move a vIST Controller node pair from one DvR domain to another.
For vIST to work properly, both Controller nodes must be in the same domain.
no router isis enable
no dvr controller
Caution
Disabling DvR on a DvR Controller destroys the domain ID and all dynamic content learned within the DvR domain. However, the switch retains the VLAN specific configuration which you can view using the command show running-config.
dvr controller <1–255>
router isis enable
Consider two vIST peer Controller nodes Switch1 (IP address 51.51.51.3) and Switch2 (51.51.51.4) that belong to a DvR domain (with domain ID 4), that you need to move to another domain (with domain ID 5).
View a summary of Controller configuration on each node:
Switch1:1(config)#show dvr
                    DVR Summary Info
Domain ID                      : 4
Domain ISID                    : 16678220
Backbone ISID                  : 16678216
Role                           : Controller
My SYS ID                      : 00:bb:00:00:81:21
Operational State              : Up
GW MAC                         : 00:00:5e:00:01:25
InjectDefaultRouteDisable(GRT) : Disabled
Switch2:1(config)#show dvr
                    DVR Summary Info
Domain ID                      : 4
Role                           : Controller
My SYS ID                      : 00:bb:00:00:82:22
Disable IS-IS globally on each Controller node:
Switch1:1>en Switch1:1>conf t Enter configuration commands, one per line. End with CNTL/Z. Switch1:1(config)#router isis Switch1:1(config-isis)#no router isis enable Switch1:1(config-isis)#exit Switch1:1(config)#
Switch2:1>en Switch2:1>conf t Enter configuration commands, one per line. End with CNTL/Z. Switch2:1(config)#router isis Switch2:1(config-isis)#no router isis enable Switch1:1(config-isis)#exit Switch1:1(config)#
Disable DvR on each node:
Switch1:1(config)#no dvr controller
Switch2:1(config)#no dvr Controller
Configure each node as a DvR Controller, with domain ID 5.
Switch1:1(config)#dvr controller 5
Switch2:1(config)#dvr controller 5
Enable IS-IS globally on each Controller node.
Switch1:1(config)#router isis Switch1:1(config-isis)#router isis enable Switch1:1(config-isis)#exit Switch1:1(config)#
Switch2:1(config)#router isis Switch2:1(config-isis)#router isis enable Switch2:1(config-isis)#exit Switch2:1(config)#
View a summary of Controller configuration on each node.
                    DVR Summary Info
Domain ID                      : 5
Domain ISID                    : 16678221
Role                           : Controller
                    DVR Summary Info
Domain ID                      : 5
Role                           : Controller
View the vIST configuration on each of the Controller nodes.
Switch1:1>show virtual-ist
                                    IST Info
PEER-IP              VLAN     ENABLE   IST
ADDRESS              ID       IST      STATUS
51.51.51.2           4002     true     up
NEGOTIATED                                    MASTER/
DIALECT      IST STATE                        SLAVE
NONE         up                               Master
Switch2:1>show virtual-ist
                                    IST Info
51.51.51.1           4002     true     up
NEGOTIATED                                    MASTER/
NONE         up                               Slave
