This procedure does not apply to VSP 8600 Series.
Use this task to view the default topology IP address for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Mgmt.
- Select the TopologyIp tab.
TopologyIp Field Descriptions
Use the data in the following table to use the TopologyIp tab.
| Name | Description |
| AddrType | Shows the IP address type for the topology IP. |
| Addr | Shows the IP address for the topology IP. |
| InterfaceName | Shows the interface name of the identified interface for the topology IP. |
| InstanceId | Specifies the interface instance for the topology IP. |
