View VRRP statistics to manage network performance.
- Click VRRP.
- Select the Interface tab.
- Select an interface.
- Click Graph.
Interface Field Descriptions
The following table describes parameters on the Interface tab.
| Name | Description |
| AdvertiseRcvd | Specifies the number of VRRP advertisements received by this virtual router. |
| AdvertiseIntervalErrors | Specifies the number of received VRRP advertisement packets with a different interval is than configured for the local virtual router. |
| IPTtlErrors | Specifies the number of VRRP packets received by the virtual router with IP TTL (Time-To-Live) not equal to 255. |
| PriorityZeroPktsRcvd | Specifies the number of VRRP packets received by the virtual router with a priority of 0. |
| PriorityZeroPktsSent | Specifies the number of VRRP packets sent by the virtual router with a priority of 0'. |
| InvalidTypePktsRcvd | Specifies the number of VRRP packets received by the virtual router with an invalid value in the 'type' field. |
| AddressListErrors | Specifies the packets received address list the address list does not match the locally configured list for the virtual router. |
| AuthTypeMismatch | Specifies the count of authentication type mismatch messages. |
| PacketLengthErrors | Specifies the count of packet length errors. |
| AuthFailures | Specifies the count of authentication failure messages. |
