Configure the forwarding database global timeout to age out dynamically learned forwarding information.
- In the navigation tree, expand the following folders:
- Click VLANs.
- Click the FdbAging tab.
- Type an interval, in seconds, for aging out dynamically learned forwarding information, or keep the default.
- Click Apply.
FDB Aging field descriptions
Use the data in the following table to use the FDB Aging tab.
| Name | Description |
| FdbAging | Specifies the timeout period for dynamically learned mac addresses on the vlan. The default valus is 300. |
