Enable and configure polling intervals to determine how frequently EDM polls for port and LED status changes or detects the hot swap of installed ports.
- Click Preference Setting.
- Enable polling or hot swap detection.
- Configure the frequency to poll the device.
- Click Apply.
Preference Setting field descriptions
Use the data in the following table to use the Preference Setting tab.
| Name | Description |
| Enable | Enables polling for port and LED status changes. The default is disabled. |
| Poll Interval | Specifies the polling interval, if enabled. The default is 60 seconds. |
| Enable | Detects the hot swap of installed ports. The default is disabled. |
| Detection per Status Poll Intervals | Specifies the number of poll intervals for detection, if enabled. The default is 2 intervals. |
