Create a Shortest Path Bridging MAC (SPBM) Backbone VLAN (B-VLAN). Each SPBM network
            instance is associated with at least one backbone VLAN (B-VLAN) in the core SPBM
            network. This VLAN is used for both control plane traffic and dataplane traffic.
            As a best practice, configure two B-VLANs in an SPBM dual-homing environment.
                In the navigation tree, expand
                    the following folders: .
                Click VLANs.
                In the Basic tab, click
                        Insert.
                In the Id box, enter an
                    unused VLAN ID, or use the ID provided.
                In the Name box, type
                    the VLAN name, or use the name provided.
                In the Color Identifier
                    box, click the down arrow and choose a color from the list, or use the color
                    provided.
                In the Type box, select
                        spbm-bvlan.
                Cick Insert.
                Collapse the VLANs tab.
                    The VLAN is added to the Basic
                        tab.
