View fan tray information to see manufacturing information about the fans.
This procedure does not apply to XA1400 Series.
- On the Device Physical View, select the Device.
- Select Chassis.
- Select the Fan Tray Info tab.
Fan Tray Info field descriptions
Use the data in the following table to use the Fan Tray Info tab.
| Name | Description |
| TrayId Note: Exception: Only
                                    supported on VSP 8600
					Series. | Specifies the fan tray ID. |
| Description | Shows a description of the fan tray. |
| SerialNumber Note: Exception: Only
					Series. | Shows the serial number for the fan tray. |
| PartNumber Note: Exception: Only
					Series. | Shows the part number for the fan tray. |
| FlowType | Specifies whether the air flow is front-to-back or back-to-front. |
