Perform this procedure to honor or ignore redirect messages for the management port. Redirect messages are visible only when Stateless Address Autoconfiguration is configured on switches capable of routing IPv6 traffic.
The default is disabled.
This procedure supports Layer 2 or Layer 3 process-redirect only on VSP 8600 Series.
Disable IPv6 forwarding.
Create an IPv6 interface.
Configure an IPv6 address.
enable
configure terminal
interface mgmtEthernet <mgmt | mgmt2>
ipv6 interface process-redirect
show ipv6 interface process-redirect
The following example shows a sample output of the show ipv6 interface process-redirect command.
Switch:1#show ipv6 interface process-redirect
                      Process ICMP redirect status
IFINDX                DESCR                VLAN                STATUS
64                   PORT-mgmt             4092                Enabled
192                  VLAN-5                5                   Disabled
2050                 VLAN-2                2                   Disabled
