This procedure does not apply to VSP 8600 Series.Procedure
- Select Mgmt Instance.
- Select Mgmt.
- Select the Interface tab.
- Select a Management Instance by placing the cursor in a cell within the applicable row.
- Select Graph.
Interface Counters Field Descriptions
Use the data in the following table to use the Interface Counters tab.
| Name | Description |
| RxPkts | Counts the packets received on the Segmented Management Instance. |
| RxError | Counts the packets received with errors on the Segmented Management Instance. |
| RxDrop | Counts the packets received and dropped on the Segmented Management Instance. |
| TxPkts | Counts the packets transmitted on the Segmented Management Instance. |
| TxError | Counts the packets transmitted with errors on the Segmented Management Instance. |
| TxDrop | Counts the packets dropped before transmission on the Segmented Management Instance. |
