Configuring a remote VTEP
Use the following procedure to configure the remote VTEP destination. The total number of VTEP remote destination IPs that you can configure is 500.
- Click VTEP.
- Click the Vtep tab.
- In the Id field, assign a unique index value to this remote VTEP.
- In the IpAddr field, enter the IP address of this remote VTEP.
- In the Name field, assign a name to this remote VTEP.
- Click Apply.
Vtep field descriptions
Use the data in the following table to use the Vtep tab.
| Name | Description |
| Id | Specifies an index value in the range from 1 to 500 that uniquely identifies this remote VTEP. |
| IpAddr | Specifies an IP address that uniquely identifies this remote VTEP. Note:
                             The remote VTEP IP address cannot be a local, broadcast, or multicast IP address. |
| Name | Assigns a name to this remote VTEP tunnel. |
| NextHopVrfName | Displays the VRF name of the next hop to reach the remote VTEP. |
| OvsdbConfigured | Specifies if the VTEP is configured with OVSDB protocol support for VXLAN Gateway. |
