This procedure only applies to XA1400 Series.
Use the following procedure to display the NIC statistics and counters.
show io nic-counters
Switch:1# show io nic-counters
======== PORT 1 NIC STATS ========
bash-4.3# ethtool -S eth1 | grep -v queue
NIC statistics:
     rx_packets: 3698179
     tx_packets: 500856
     rx_bytes: 273670137
     tx_bytes: 67740387
     rx_broadcast: 1905912
     tx_broadcast: 117620
     rx_multicast: 1622656
     tx_multicast: 285392
     multicast: 1622656
     collisions: 0
     rx_crc_errors: 0
     rx_no_buffer_count: 0
     rx_missed_errors: 0
     tx_aborted_errors: 0
     tx_carrier_errors: 0
     tx_window_errors: 0
     tx_abort_late_coll: 0
     tx_deferred_ok: 0
     tx_single_coll_ok: 0
     tx_multi_coll_ok: 0
     tx_timeout_count: 0
     rx_long_length_errors: 0
     rx_short_length_errors: 0
     rx_align_errors: 0
     tx_tcp_seg_good: 0
     tx_tcp_seg_failed: 0
     rx_flow_control_xon: 0
     rx_flow_control_xoff: 0
     tx_flow_control_xon: 0
     tx_flow_control_xoff: 0
     rx_long_byte_count: 273670137
     tx_dma_out_of_sync: 0
     tx_smbus: 0
     rx_smbus: 0
     dropped_smbus: 0
     os2bmc_rx_by_bmc: 0
     os2bmc_tx_by_bmc: 0
     os2bmc_tx_by_host: 0
    os2bmc_rx_by_host: 0
     tx_hwtstamp_timeouts: 0
     rx_hwtstamp_cleared: 0
     rx_errors: 0
     tx_errors: 0
     tx_dropped: 0
     rx_length_errors: 0
     rx_over_errors: 0
     rx_frame_errors: 0
     rx_fifo_errors: 0
     tx_fifo_errors: 0
     tx_heartbeat_errors: 0
