Configure IGMP sender entries to identify a source that sends multicast data to a multicast group.
You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must first launch the appropriate VRF context.
- In the navigation pane, expand the following folders: .
- Click IGMP.
- Click the Sender tab.
- Change the appropriate options.
- Click Apply.
Sender field descriptions
Use the data in the following table to use the Sender tab.
| Name | Description |
| IfIndex | Specifies the interface where you enabled the IGMP entry. |
| GrpAddr | Specifies the multicast group address of the multicast stream. Within the indicated valid range (224.0.0.0 to 239.255.255.255), the following are invalid addresses: 244.0.0.x and the corresponding 31 multicast addresses that map to the IP MAC addresses. If you try to select them, you receive an invalid message. |
| MemberAddr | Specifies the IP address of a host. |
| Action | Flushes an entry or a group. |
| TPort | Identifies the T port. |
| State | Indicates whether a sender exists because of an IGMP access filter. The options are filtered and not filtered. |
| L2Isid | Specifies the Layer 2 I-SID of the C-VLAN. |
