Use the following procedure to display the global IS-IS parameters.
Switch:1>show isis
                               ISIS General Info
                            AdminState : enabled
                            RouterType : Level 1
                             System ID : 0014.c7e1.33df
                  Max LSP Gen Interval : 900
                                Metric : wide
                   Overload-on-startup : 20
                              Overload : false
                         Csnp Interval : 10
                         PSNP Interval : 2
                     Rxmt LSP Interval : 5
                             spf-delay : 100
                           Router Name : Switch1
                     ip source-address : 41.41.41.100
                   ipv6 source-address : 41:0:0:0:0:0:0:100
              ip tunnel source-address : 11.11.12.11
                            Tunnel vrf : spboip
                         ip tunnel mtu : 1950
                     Num of Interfaces : 2
                 Num of Area Addresses : 1
                        inband-mgmt-ip :
                              backbone : disabled
              Dynamically Learned Area : 00.0000.0000
                            FAN Member : No
                         Hello Padding : enabled
                  Multi-Area OperState : disabled
                      Multi-Area Flags : home-always-up
      Switch# show isis system-id
                                 ISIS System-Id
SYSTEM-ID	      AREA                 AREA-NAME
0014.c7e1.33df        HOME
      Switch# show isis net
                                 ISIS Net Info
NET
c0.2000.0000.0000.14c7.e133.df00
