This procedure only applies to the VSP 7400 Series.
Perform this procedure to apply the Multi-area SPB layer 2 multicast redistribution that you configure in the home area.
- Select MultiArea
- Select the L2 MC Apply Home tab.
- In the McastApply field, select apply.
L2 MC Apply Home Field Descriptions
Use data in the following table to use the L2 MC Apply Home tab.
| Name | Description |
| McastApply | Applies or disables the Multi-area SPB layer 2 multicast redistribution in the home area.
