Globally enable or disable EAP on the switch. By default, EAP is disabled.
Global field descriptions
Use the data in the following table to use the Global tab.
| Name | Description |
| EapolVersion | Displays the EAP version on the switch. |
| AccessControl | Enables system authentication control. EAP is disabled by default. |
| NonEapRadiusPwdAttrFmt | Specifies the password attribute format for non EAP RADIUS authentication.
| NonEapRadiusPwdAttrKeyString | Specifies the attribute key string for non EAP RADIUS password. |
| ClearNonEap | Clears the NEAP session that is learned on the switch. |
| AutoIsidOffset Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series. | Specifies the Auto I-SID Offset value. |
| AutoIsidOffsetEnable Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series. | Enables or disables the Auto I-SID Offset feature. |
