Clear all IPv6 statistics if you do not require previous statistics.
Use the information in the following table to use the clear ipv6 statistics commands.
| Variable | Value |
| gigabitethernet {slot/port[/sub-port]} | Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| loopback <1–256>> | Identifies a loopback interface. |
| mgmtethernet mgmt Note:
                                     Exception: only supported on VSP 8600 Series. | Identifies the management interface. This parameter only applies to hardware with a dedicated, physical management interface. |
| tunnel <1-2000> | Identifies a 6in4 tunnel ID. |
| vlan<1-4059> | Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. |
| vrf WORD<1–16> | Specifies the VRF name. |
| vrfids WORD<0–512> | Specifies the VRF ID. |
