This procedure only applies to VSP 4900 Series.
Perform this procedure to display information about an installed Solid State Drive (SSD) on a switch.
- Select Chassis.
- Select the SSD tab.
SSD Field Descriptions
Use the data in the following table to use the SSD tab.
| Name | Description |
| ProductName | Specifies Solid State Drive (SSD) product name. |
| VendorName | Specifies the SSD vendor. |
| ManufactureDate | Specifies the date on which the SSD was manufactured. |
| SerialNum | Specifies the SSD serial number. |
| PartNum | Specifies the SSD part number. |
| DeviceVersion | Specifies the version of the SSD. |
| TotalSize | Specifies the total memory size of the SSD. |
