Use the following options to display Layer 2 VSN information to confirm proper configuration.
show isis spbm ip-multicast-route [all]
show isis spbm ip-multicast-route [detail]
show isis spbm ip-multicast-route [vlan <1-4059>]
show isis spbm ip-multicast-route [vsn-isid <1–16777215>]
show isis spbm ip-multicast-route [group {A.B.C.D}]
show isis spbm ip-multicast-route [source {A.B.C.D}]
Important
When you use the command show isis spbm ip-multicast-route without parameters or use the detail or group optional parameters without specifying a VLAN ID or VSN I-SID, the command output displays Layer 3 context only. No Layer 2 context is displayed.
show isis spb-mcast-summary [count][host-name WORD<0–255>][lspid <xxxx.xxxx.xxxx.xx-xx>]
Switch:1#show isis spbm ip-multicast-route all
       SPBM IP-MULTICAST ROUTE INFO ALL
Type   VrfName   Vlan Source      Group       VSN-ISID  Data ISID  BVLAN Source-BEB
                 Id
snoop   GRT      501  192.0.2.1   233.252.0.1   5010     16300001   10    el2
snoop   GRT      501  192.0.2.1   233.252.0.2   5010     16300002   20    el2
snoop   GRT      501  192.0.2.1   233.252.0.3   5010     16300003   10    el2
snoop   GRT      501  192.0.2.1   233.252.0.4   5010     16300004   20    el2
snoop   GRT      501  192.0.2.1   233.252.0.5   5010     16300005   10    el2
snoop   GRT      501  192.0.2.1   233.252.0.6   5010     16300006   20    el2
snoop   GRT      501  192.0.2.1   233.252.0.7   5010     16300007   10    el2
snoop   GRT      501  192.0.2.1   233.252.0.8   5010     16300008   20    el2
snoop   GRT      501  192.0.2.1   233.252.0.9   5010     16300009   10    el2
snoop   GRT      501  192.0.2.1   233.252.0.10  5010     16300010   20    el2
 Total Number of SPBM IP MULTICAST ROUTE Entries: 10
Switch:1#show isis spbm ip-multicast-route vlan 501
                 Id
Switch:1# show isis spbm ip-multicast-route vsn-isid 5010
=========================================================================                          SPBM IP-MULTICAST ROUTE INFO - VLAN ID : 501, VSN-ISID : 5010
Source          Group           Data ISID  BVLAN Source-BEB
192.0.2.1      233.252.0.1    16300001   10    el2
192.0.2.1      233.252.0.2    16300002   20    el2
192.0.2.1      233.252.0.3    16300003   10    el2
192.0.2.1      233.252.0.4    16300004   20    el2
192.0.2.1      233.252.0.5    16300005   10    el2
192.0.2.1      233.252.0.6    16300006   20    el2
192.0.2.1      233.252.0.7    16300007   10    el2
192.0.2.1      233.252.0.8    16300008   20    el2
192.0.2.1      233.252.0.9    16300009   10    el2
192.0.2.1      233.252.0.10   16300010   20    el2
Switch:1# show isis spbm ip-multicast-route vsn-isid 5010 detail
SPBM IP-MULTICAST ROUTE INFO - TYPE : SNOOP , VLAN ID : 501, VSN-ISID : 5010
Source 	   Group 	Data ISID BVLAN  NNI Rcvrs 	UNI Rcvrs Source-BEB
192.0.2.1 233.252.0.1  16300001 10 	1/3 		V501:9/38 el2
192.0.2.1 233.252.0.2  16300002 20 	1/2,1/3 	V501:9/38 el2
192.0.2.1 233.252.0.3  16300003 10 	1/3 		V501:9/38 el2
192.0.2.1 233.252.0.4  16300004 20 	1/2,1/3 	V501:9/38 el2
192.0.2.1 233.252.0.5  16300005 10 	1/3 		V501:9/38 el2
192.0.2.1 233.252.0.6  16300006 20 	1/2,1/3 	V501:9/38 el2
192.0.2.1 233.252.0.7  16300007 10 	1/3 		V501:9/38 el2
192.0.2.1 233.252.0.8  16300008 20 	1/2,1/3 	V501:9/38 el2
192.0.2.1 233.252.0.9  16300009 10 	1/3 		V501:9/38 el2
192.0.2.1 233.252.0.10 16300010 20 	1/2,1/3 	V501:9/38 el2
Switch:1# show isis spb-mcast-summary
                SPB Multicast - Summary
SCOPE    SOURCE           GROUP            DATA            LSP  HOST
I-SID    ADDRESS          ADDRESS          I-SID     BVID  FRAG NAME
5010     192.0.2.1       233.252.0.1     16300001  10    0x0  el2
5010     192.0.2.1       233.252.0.3     16300003  10    0x0  el2
5010     192.0.2.1       233.252.0.5     16300005  10    0x0  el2
5010     192.0.2.1       233.252.0.7     16300007  10    0x0  el2
5010     192.0.2.1       233.252.0.9     16300009  10    0x0  el2
5010     192.0.2.1       233.252.0.2     16300002  20    0x0  el2
5010     192.0.2.1       233.252.0.4     16300004  20    0x0  el2
5010     192.0.2.1       233.252.0.6     16300006  20    0x0  el2
5010     192.0.2.1       233.252.0.8     16300008  20    0x0  el2
5010     192.0.2.1       233.252.0.10    16300010  20    0x0  el2
192.0.2.1    233.252.0.1  16300001 10    1/4,MLT-35 	V501:9/32-9/33 	el2
192.0.2.1    233.252.0.3  16300002 20 	 - 		V501:9/32-9/33 	el2
192.0.2.1    233.252.0.5  16300003 10 	 1/4,MLT-35 	V501:9/32-9/33 	el2
192.0.2.1    233.252.0.7  16300004 20 	 - 		V501:9/32-9/33 	el2
192.0.2.1    233.252.0.9  16300005 10 	 1/4,MLT-35 	V501:9/32-9/33 	el2
192.0.2.1    233.252.0.2  16300006 20 	 - 		V501:9/32-9/33 	el2
192.0.2.1    233.252.0.4  16300007 10 	 1/4,MLT-35 	V501:9/32-9/33 	el2
192.0.2.1    233.252.0.6  16300008 20 	 - 		V501:9/32-9/33 	el2
192.0.2.1    233.252.0.8  16300009 10 	 1/4,MLT-35 	V501:9/32-9/33 	el2
192.0.2.1    233.252.0.10 16300010 20 	 - 		V501:9/32=9/33 	el2
