Configure an ACE to filter IPv6 routed packets only.
This procedure does not apply to VSP 8600 Series or XA1400 Series.
- The ACL exists.
- The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the Ipv6Routed tab.
- Select Insert.
- In the AclId field, type the appropriate ACL ID.
- In the AceId field, type the appropriate ACE ID.
- Select RoutedOnly.
- Select Insert.
Ipv6Routed Field Descriptions
The following table describes values on the Ipv6Routed tab.
| Name | Description |
| AclId | Specifies the ACL ID. |
| AceId | Specifies the ACE ID. |
| RoutedOnly | Specifies the match for IPv6 routed packets only. |
