Configure RADIUS accounting interim requests to create a log whenever a user executes more than the number of CLI commands you specify.
If the packet size equals or exceeds 1.8 KB, an interim request packet is sent even if the configured limit is not reached. Therefore, the trigger to send out the interim request is either the configured value or a packet size greater than, or equal to 1.8 KB, whichever happens first.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# radius cli-cmd-count 30 Switch:1(config)# radius accounting include-cli-commands
The following table defines parameters for the radius cli-cmd-count command.
| Variable | Value |
| <1-40> | Specifies how many CLI commands, from 1 to 40, before the system sends a RADIUS accounting interim request. The default value is 40. |
