View BGP Route Summary
Display BGP route summary.
                                        To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
                                        The VRF must have an RP trigger of BGP.
- Select BGP.
- Select the Bgp Route Summary tab.
Bgp Route Summary field descriptions
Use the data in the following table to use the Bgp Route Summary tab.
| Name | Description |
| Prefix | Configures the IP address of the route. |
| PrefixLen | Specifies the IP address and the mask length (the length can be 0–32). |
| LocalAddr | Specifies the local IP address of the entered BGP route. |
| RemoteAddr | Specifies the remote IP address of the entered BGP route. |
