Use the following procedure to display SPBM nicknames.
- Select SPBM.
- Select the Nick Names tab.
Nickname field descriptions
Use the data in the following table to use the NickName tab.
| Name | Description |
| Level | Indicates the level at which the system displays this LSP. |
| ID | Indicates the 8 byte LSP ID, consisting of the SystemID, Circuit ID, and Fragment Number. |
| LifetimeRemain | Indicates the remaining lifetime in seconds for the LSP. |
| NickName | Indicates the nickname for the SPBM node. |
| HostName | Indicates the hostname listed in the LSP, or the system name if the host name is not configured. |
