View graphs for OSPF on a VLAN. The graph formats available are: line chart, area chart, bar chart, and pie chart.
- OSPF must be enabled.
OSPF graph field descriptions
Use the data in the following table to use the OSPF graph tab.
| Name | Description |
| AbsoluteValue | Displays the counter value. |
| Cumulative | Displays the total value since you opened the OSPF-Graph tab. |
| Average/sec | Displays the average value for each second. |
| Minimum/sec | Displays the minimum value for each second. |
| Maximum/sec | Displays the maximum value for each second. |
| LastVal/sec | Displays the last value for each second. |
| VersionMismatches | Displays the number version mismatches received by this interface. |
| AreaMismatches | Displays the number area mismatches received by this interface. |
| AuthTypeMismatches | Displays the number AuthType mismatches received by this interface. |
| AuthFailures | Displays the number Authentication failures. |
| NetMaskMismatches | Displays the number net mask mismatches received by this interface. |
| HelloIntervalMismatches | Displays the number hello interval mismatches received by this interface. |
| DeadIntervalMismatches | Displays the number dead interval mismatches received by this interface. |
| OptionMismatches | Displays the number options mismatches received by this interface. |
| RxHellos | Displays the number hello packets received by this interface. |
| RxDBDescrs | Displays the number database descriptor packets received by this interface. |
| RxLSUpdates | Displays the number Link state update packets received by this interface. |
| RxLSReqs | Displays the number Link state request packets received by this interface. |
| RxLSAcks | Displays the number Link state acknowledge packets received by this interface. |
| TxHellos | Displays the number hello packets transmitted by this interface. |
| TxDBDescrs | Displays the number database descriptor packets transmitted by this interface. |
| TxLSUpdates | Displays the number Link state update packets transmitted by this interface. |
| TxLSReqs | Displays the number Link state request packets transmitted by this interface. |
| TxLSAcks | Displays the number Link state acknowledge packets transmitted by this interface. |
