This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the remote hello multiplier to specify how many hellos the switch must miss before it considers the adjacency with a neighboring switch down.
Configuring the remote hello multiplier on port 1/2:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#isis remote l1-hello-multiplier 1
The following table defines parameters for the isis remote l1-hello-multiplier command.
| Variable | Value |
| <1-600> | Configures the Level 1 hello multiplier. The default value is 3 seconds. |
