Configure an IS-IS accept policy for a specific I-SID list to represent local or remote Layer 3 VSNs, which allows the system to redistribute the remote VSNs to the VSN where you applied the filter.
If the route policy changes, you must re-apply the IS-IS accept policy, unless it was the last sequence in the configuration.
                                        Enable IS-IS globally.
                                        Ensure the manual area exists.
                                        You must configure a route-map to apply.
- Click IS-IS.
- Click the Accept Isid-List tab.
- Click Insert.
- In the Name field, specify the I-SID list name.
- Select enable in the Enable check box to enable the filter.
- In the PolicyName field, specify the route-map name.
- Click Insert.
Accept Isid–List field descriptions
Use the data in the following table to configure Accept Isid-List tab.
| Name | Description |
| Name | Specifies the name of I-SID list. |
| Enable | Enables or disables the I-SID list entry. The value must be enabled to filter. The default is disabled. |
| PolicyName | Specifies the route policy name. |
| BackBonePolicyName | Specifies the backbone route policy name. |
