This procedure only applies to the VSP 7400 Series.
Perform this procedure to view statistical graph of the remote IS-IS interface receiving control packets.
- Select IS-IS Remote.
- Select the Interfaces tab.
- Select an interface.
- Select the Graph button.
- Select the Interface Receiving Control Packets tab.
Interface Receiving Control Packets Field Descriptions
Use data in the following table to use the Interface Receiving Control Packets tab.
| Name | Description |
| Hello | Indicates the number of IS-IS Hello PDUs seen in this direction at this level. Point-to-Point IIH PDUs are counted at the lowest enabled level: at L1 on L1 or L1L2 circuits, and at L2 otherwise. |
| LSP | Indicates the number of IS-IS link-state packet (LSP) frames seen in this direction at this level. |
| CSNP | Indicates the number of IS-IS Complete Sequence Number Packet (CSNP) frames seen in this direction at this level. |
| PSNP | Indicates the number of IS-IS Partial Sequence Number Packets (PSNPs) seen in this direction at this level. |
| AbsoluteValue | Displays the counter value. |
| Cumulative | Displays the total value since you opened the Stats tab. |
| Average/Sec | Displays the average value for each second. |
| Minimum/Sec | Displays the minimum value for each second. |
| Maximum/Sec | Displays the maximum value for each second. |
| Last Val/Sec | Displays the last value for each second. |
