Configure a black hole static route to the destination a router advertises to avoid routing loops after the router aggregates or injects routes to other routers.
If a black hole route is enabled, you must first delete or disable it before you can add a regular static route to that destination.
Only black hole routes that belong to the static type protocol are supported. An inter-VRF black hole route is not installed in the routing table of the destination VRF on the same switch.
Create a black hole static route and enable the black hole static route.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip route 192.0.2.0 255.255.0.0 255.255.255.255 weight 200 Switch:1(config)#ip route 192.0.2.0 255.255.0.0 255.255.255.255 enable
Use the data in the following table to use the ip route command.
| Variable | Value |
| <A.B.C.D> | The first and second <A.B.C.D> specify the IP address and mask for the route destination. 255.255.255.255 is the destination of the black hole route. |
| enable | Adds a static route to the router or VRF. The no form of this command is no ip route <A.B.C.D> <A.B.C.D> 255.255.255.255 enable. |
| local-next-hop enable | Enables the local next hop for this static route. The default form of this command is default ip route <A.B.C.D> <A.B.C.D> <A.B.C.D> local-next-hop enable. The no form of this command is no ip route <A.B.C.D> <A.B.C.D> 255.255.255.255 local-next-hop enable. |
| next-hop-vrf WORD<1-16> | Specifies the next-hop VRF instance by name. The default form of this command is default ip route <A.B.C.D> <A.B.C.D> 255.255.255.255 next-hop-vrf <WORD 1-16>. The no form of this command is no ip route <A.B.C.D> <A.B.C.D> 255.255.255.255 next-hop-vrf <WORD 1-16>. |
| weight <1-65535> | Specifies the static route cost. The default form of this command is default ip route <A.B.C.D> <A.B.C.D> 255.255.255.255 weight. Note:
                                     Do not configure a static interface subnet route with a weight of 1. |
| preference <1-255> | Specifies the route preference. The default form of this command is default ip route <A.B.C.D> <A.B.C.D> 255.255.255.255 preference. |
