Use the following procedure to add the common name of the Certificate Authority.
This procedure does not apply to VSP 8600 Series.Procedure
- Select System Log.
- Select Certificate Table tab.
- Select Insert.
- In the CaCommonName field, enter the common name of the Certificate Authority.
- Select Insert.
Certificate Table Field Definitions
Use the data in the following table to use the Certificate Table
        tab.
        | Name | Description |
| CaCommonName | Specifies the Certificate Authority common name of a syslog server. |
