Change the state (active or passive) of PIM on a VLAN interface.
- Before you change
the state of PIM on a VLAN interface, you must first disable PIM to
prevent instability in the PIM operations, especially when neighbors
exist or when the interface receives streams.
- In the navigation pane,
expand the following folders: .
- Click VLANs.
- Click the Basic tab.
- Select the VLAN ID
that you want to configure with PIM.
- Click IP.
- Click the PIM tab.
- Clear the Enable check
box.
- Click Apply.
- Select active or passive.
- Reenable PIM on the
VLAN interface.
- Click Apply.
