Use this procedure to determine the data stream learned when IP Multicast over Fabric Connect is configured on the VLAN.
The following section shows sample output for the show ip mroute route command.
In this table, every stream uses one (*,G) entry and x (S,G) entries, depending on how many servers forward traffic to the same group.
The 0.0.0.0 mask is always tied to a (*,G) entry.
If you do not specify a VRF name or range of VRF IDs, the results display information for the Global Router. If you do specify a VRF name or range of VRF IDs, the results display information only for the VRFs you specify.
Determine the data stream learned:
Switch:1>show ip mroute route
                          Mroute Route - GlobalRouter
GROUP           SOURCE          SRCMASK         UPSTREAM_NBR    IF     EXPIR  PROT
233.252.0.1       0.0.0.0         0.0.0.0         0.0.0.0        V3       30 spb-access
233.252.0.1       192.0.2.102     255.255.255.0   0.0.0.0        -        0  spb-network
233.252.0.2       0.0.0.0         0.0.0.0         0.0.0.0        V2      30  pimsm
225.1.1.1         198.51.100.99   255.255.255.0   0.0.0.0        V3      173 spb-pim-gw
Total 4
The following table defines parameters for the show ip mroute route command.
| Variable | Value |
| vrf WORD<0–32> | Specifies the VRF name. |
| vrfids <0–255> | Specifies the VRF ID. |
