Associating VLANs with an ACL
Associate VLANs with an ACL to apply filters to VLAN traffic.
A VLAN can be part of two different ACLs of different types: IPv6 and non-IPv6.
- The ACL exists.
Variable definitions
Use the data in the following table to use the filter acl vlan command.
| Variable | Value |
| <acl-id> | Specifies the ACL ID. Use the CLI Help to see the available range for the switch. |
| <1-4059> | Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. |
