This procedure does not apply to VSP 8600 Series.
Use this task to view IP ICMP statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IP-ICMP tab.
- To clear IP statistics, select Clear Stats.
- To clear IP counters, select Clear Counters.
IP-ICMP Field Descriptions
Use the data in the following table to use the IP-ICMP tab.
| Name | Description |
| InMsgs | Shows the inbound messages statistics. |
| InErrors | Shows the inbound errors statistics. |
| InCsumErrors | Shows the inbound checksum errors statistics. |
| InDestUnreachs | Shows the inbound destination unreachable statistics. |
| InTimeExcds | Shows the inbound time exceeded statistics. |
| InParmProbs | Shows the inbound parameter problems statistics. |
| InSrcQuenchs | Shows the inbound source quenchs statistics. |
| InRedirects | Shows the inbound redirects statistics. |
| InEchos | Shows the inbound echos statistics. |
| InEchoReps | Shows the inbound echo replies statistics. |
| InTimestamps | Shows the inbound timestamps statistics. |
| InTimestampsReps | Shows the inbound timestamp replies statistics. |
| InAddrMasks | Shows the inbound address masks statistics. |
| InAddrMaskReps | Shows the inbound address mask replies statistics. |
| OutMsgs | Shows the outbound messages statistics. |
| OutErrors | Shows the outbound errors statistics. |
| OutDestUnreachs | Shows the outbound destination unreachable statistics. |
| OutTimeExcds | Shows the outbound time exceeded statistics. |
| OutParmProbs | Shows the outbound parameter problems statistics. |
| OutSrcQuenchs | Shows the outbound source quenchs statistics. |
| OutRedirects | Shows the outbound redirects statistics. |
| OutEchos | Shows the outbound echos statistics. |
| OutEchoReps | Shows the outbound echo replies statistics. |
| OutTimestamps | Shows the outbound timestamps statistics. |
| OutTimestampReps | Shows the outbound timestamps replies statistics. |
| OutAddrMasks | Shows the outbound address masks statistics. |
| MsgInType0 | Shows the inbound Type0 messages statistics. |
| MsgOutType8 | Shows the outbound Type8 messages statistics. |
