Perform the following procedure to clear the VLACP Flap Detect and Damping statistics for a specific VLACP port or all VLACP ports on the switch.
Switch:1>enable Switch:1#clear vlacp flap-stats port 2/11
Use data in the following table to use the clear vlacp flap-stats command.
| Variable | Value |
| port{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} | Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
