Use the following procedure to display the SPB-PIM Gateway VLAN interface information.
Switch:1>show ip spb-pim-gw interface
                      Spb-pim-gw Interface - GlobalRouter
IF        ADDR            MASK            JPINT      HELLOINT   OPSTATE    ADMINSTATE
Vlan50    50.1.1.1        255.255.255.0   60         30         Disabled   Enabled
Vlan123   123.1.1.1       255.255.255.0   60         30         Disabled   Disabled
Vlan142   142.1.1.1       255.255.255.0   60         30         Enabled    Enabled
Vlan400   100.1.1.2       255.255.255.0   60         30         Disabled   Disabled
Total spb-pim-gw Interfaces Displayed 4/4
Variable definitions
The following table defines parameters for the show ip spb-pim-gw interface command.
| Variable | Value |
| vlan-id | The VLAN ID of an interface to display. |
