After you configure the BOOTP/DHCP relay on an IP interface, you can configure forwarding paths to indicate where packets are forwarded. The forwarding paths are based on the type of packet and where the packet is received.
Globals field descriptions
Use the data in the following table to use the Globals tab.
Name |
Description |
AgentAddr |
The IP address of the input interface (agent) on which the BOOTP/DHCP request packets are received for forwarding. This address is the IP address of either a brouter port or a VLAN for which forwarding is enabled. |
ServerAddr |
This parameter is either the IP address of the BOOTP/DHCP server or the address of another local interface.
Enable |
Enables BOOTP/DHCP relay. |
Mode |
Specifies the type of messages relayed:
The default is to forward both BOOTP and DHCP messages. |
SrcPort67 Note:
Exception: not supported on VSP 8600 Series. |
Assigns source port 67 to the UDP forwarding path. The default is source port 68. |
